TFL 41" (1040mm) Zonda RC Boat, Twin Drive and Carbon Fiber. This boat is a hardware-only version. Pictures showing the esc's and motors are for display purposes only.
Now in three different color decal sets, Green, Pink or Purple.This is the Drag Boat version of the Zonda. Built for high-speed straight-line racing with its Kevlar inlay and 4082-sized motors. What makes the OSE Zonda different? (1) Set of Left and Right TFL One Piece Cables(1) Set of metal CNC Left and Right Props(4) Thru-hull water pickups, see picture 5.(2) Carbon Battery Slides, see picture 7. TFL built this boat out of carbon fiber for it to be both super strong and very lightweight. Both are very important if you're trying to make a fast electric RC boat. This boat comes assembled with all high-quality equipment, including CNC aluminum hardware. Some of the major components include,Carbon fiber hull for lightweight and super strength.Adjustable twin struts for fine-tuning.CNC left and right counter-rotating propellers. Requires: (1) Steering Servo - 30kg or stronger (1) 2-Channel Radio System(1) Charger (2) Motors (2) esc's(2) 3s or (2) 6s Lipo packs Hull Specs: Material: Carbon Fiber Length from tips to rudder mounting area: 41" (1040mm) Length of riding surface: 36.5" (927mm)Width at widest point: 11.75" (299mm)
