TFL 41" (1040mm) Zonda GT RC Boat, Twin Drive in Blue and White Fiberglass paint scheme. This is the Drag Boat version of the Zonda. Built for high-speed straight-line racing with its Kevlar inlay and 4082-sized motors. To make this boat even lighter, we include a 6s wiring harness. This harness allows you to run (2) 3s lipo packs that will wire the packs to run 6s to each esc. No other place is building them this way! Alternatively, you can unplug the harness and run a 6S LiPo pack to each ESC. What makes the OSE Zonda different? (2) Seaking 160v4, see picture 4.(2) SSS 4082 V2 2000kv Motors, see picture 4.(1) Set of Left and Right TFL One Piece Cables(1) Set of CNC Props(4) Thru-hull water pickups, see picture 2 (new round design as of May 2024).(2) Adjustable Carbon Battery Slides, see pictures 3 & 4. (1) OSE EC5 parallel esc to series battery harness, see picture 6. Some of the major components include, Two Seaking 160 v4 ESCs for performance and waterproof for reliability.Two TFL SSS 4082 v2 2000kv Brushless Motors for over 6 Horsepower.Adjustable twin struts for fine-tuning.CNC counter-rotating propellers. ARTR (almost ready to run). It requires a servo, a 2-channel radio, and batteries. Requires: (1) Steering Servo (1) 2-Channel Radio System(1) ChargerBatteries:(2) 3s or (2) 6s Lipo packs with EC5 connectors Hull Specs: Material: Fiberglass Length Tips to rudder mounting area: 41" (1040mm) Length of ridding surface: 36.5" (927mm)Width at widest point: 11.75" (299mm)NOTE: We recommend using the tape-to-tape method for securing this cowl shut; it will help preserve the paint design. See our articles section on how to do this.
