TFL 41" (1040mm) Zonda Rc Boat, Twin Drive and Carbon fiber.
Now in three different color decal sets, Green, Pink or Purple.This is the Drag Boat version of the Zonda. Built for high-speed straight-line racing with its Kevlar inlay and 4082-sized motors. To make this boat even lighter, we include a 6s wiring harness. This harness allows you to run (2) 3s lipo packs that will wire the packs to run 6s to each esc. No other place is building them this way! Or you can unplug the harness and run a 6s lipo pack to each esc. What makes the OSE Zonda different? (2) Seaking 160v4, see picture 6.(2) SSS 4082 V2 2000kv Motors, see picture 6.(1) Set of Left and Right TFL One Piece Cables(1) Set of metal CNC Left and Right Props(4) Thru-hull water pickups, see picture 5.(2) Carbon Battery Slides, see picture 7. (1) OSE EC5 parallel esc to series battery harness, see picture 11. TFL built this boat out of carbon fiber for it to be both super strong and very lightweight. Both are very important if you're trying to make a fast electric RC boat. This boat comes assembled with all high-quality equipment, including CNC aluminum hardware. Some of the major components include, Carbon fiber hull for lightweight and super strength. Two Seaking v4 160 ESCs for performance and waterproofing for reliability.Two TFL SSS 4082 v2 2000kv Brushless Motors for over 6 Horsepower.Adjustable twin struts for fine-tuning.CNC left and right counter-rotating propellers. ARTR (almost ready to run). It requires a servo, a 2-channel radio, and batteries. Requires: (1) Steering Servo - 30kg or stronger (1) 2-Channel Radio System(1) ChargerBatteries:(2) 3s or (2) 6s Lipo packs with EC5 connectors. Hull Specs: Material: Carbon Fiber Length Tips to rudder mounting area: 41" (1040mm) Length of ridding surface: 36.5" (927mm)Width at widest point: 11.75" (299mm)
