TFL Fiberglass Cheetah: Twin 4082 2000kv motors & Seaking 200 v4 ESC's : ARTR (Almost Ready to Run)Paint is available in either Red or White Just like a Cheetah, TFL has designed this hull to be both fast and agile around corners. All pieces are either carbon fiber or aluminum to withstand the force at such high speeds. With the right setup and tuning, this setup can reach speeds close to 70mph. Specs: ESC: (2) Seaking 200 v4Escs with 6mm bullet connectors Motors: (2) TFL SSS-4082-2000kv Flex Cable .187 Flex Cable Propeller Shaft: 3/16" Propeller shaft for use with all the popular propellers on the market. Adjustable struts. Water pickup rudder with a breakaway screw to stop damage when objects are hit. Battery tray: Carbon fiber, center mount. Coupler: 5mm - .187 coupler It can be powered with 4s to 6s Lipo. Specs: Length: 34.00" (864mm) Width: 13.50" (343mm) at the widest point. Requires: (2) 4s or 6s 50c 5000mah lipo packs with ec5 connectors with a height of 39mm or less.(1) High torque servo(1) Radio System
