One left in Blue Color.TFL Popeye Hydro : Hardware OnlyThis boat comes assembled with all high-quality equipment, including CNC aluminum hardware.Includes: -Fiberglass hull for lightweight and high strength. -Water pickup rudder with the kick-up rudder. -Aluminum Strut -Metal 38mm copper propeller. -Propeller shaft 3/16" (4.75mm) diameter. -Flex Cable .187(4.75mm) diameter. -ARTR(almost ready to run). -Fiberglass battery tray Boat Specs: Total length with hardware: 35"(895mm) Hull length: 32" (820mm) Hull width: 14.35" (365mm) Requires:(1) Motor 4074 or 4082 (1) Esc, Seaking, xc or Hydra(1) Standard-size servo for steering (1) 2-Channel Radio System (1) 4s 45c 5000 MAH Lipo pack with EC5.(1) Charger for your battery pack
