OSE Flex Cable Assembly for the AquaCraft UL-1. Upgraded .150" Cable with 3/16" prop shaft.
This is cut and ready to install in your boat. This upgraded cable is higher quality, with thicker wire strands, and is better aligned with the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. No soldering or cutting required!
This can also be used in any other boat requiring a .150 cable that measures 13 11/16" from tip to tip.
Includes: Teflon Liner, .150 cable with 3/16" prop shaft and attached drive dog and brass bullet nut.
Picture shows the stock and upgraded OSE cable side by side.
