OSE Flex Cable Assembly for the AquaCraft Lucas Oil or the Motley Crew Catamaran. Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is a higher quality with thicker wire strands and better aligned to the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
No soldering or cutting required!
This can also be used in any other boat requiring a .150 cable that measures 14 3/4" from tip to tip.
Includes: Teflon Liner, .150 cable with 3/16" prop shaft and attached drive dog and streamlined bullet nut.
Picture shows the stock and upgraded OSE cable side by side.
