OSE cable for the ProBoat Blackjack 29 v1. The version that comes stock with the 1800kv motor. Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is of higher quality with thicker wire strands and is better aligned to the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For 6s lipo, use the HD cable.
No soldering or cutting is required!
This can also be used in any other boat requiring a .150 cable that measures 12.75" (325mm) (+/- .1") from tip to tip. We suggest using part number oct-ocfhe5mm15S coupler with this shaft and the ProBoat Blackjack 29.
