OSE assembled a .130 flex cable with a prop shaft that is a step-down from 3/16" to 1/8" for 1/8" propellers. The propeller shaft works with 3/16" struts. This option is good for high-powered small boats that need the strength of larger cables and prop shafts. Our assembled systems use the latest in assembly technology. We don't heat the cable in our process. This helps solve the breaking problems at the solder joint that other companies have.
Includes: .130 cable, approx 16" total assembled length, end to end. .130 teflon liner 3/16" to 1/8" stepdown prop shaft pn#oct-oc64pkgps 1/8 brass drive dog pn# oct-oc4d 1/8 brass bullet nut pn# oct-oc4pn Requires: 7/32 OD K&S brass tubing for stuffing tube when used with the Teflon liner.Cable cut to your desired length.
