Castle Creations BEC Eliminator Circuit, Eliminates the need for a RX Pack!
Are you running a receiver pack or having it die in the middle of the lake? Tired of having a dead receiver pack ruin your day? Tired of buying AA batteries to power your receiver? Need to shed some weight from your Fast Electric? If you answered yes to any of these questions you have found the right product. The Castle PRO BEC is intended for use in larger RC cars, electric aircraft, and helicopters that have high power demands for their radio/servo systems. It is ideal for most electric helis 500-size and larger. It will also work well in larger electric powered RC aircraft and RC crawlers and Monster Trucks that have high-powered servos.Key Features - Rated for up to 12S input (50.4 volts) - Peak Output of up to 20 amps - Fully adjustable using the Castle Link USB Adapter and a Windows PC - Length: 1.69" (43mm) - Width: 1.3" (33mm) - Height: .94" (24mm) - Weight: 1 oz (29 grams) without wires
