New item, but Open Box Return, Save $30.00
Spektrum 4685 740kv: 4-pole brushless marine motor with water jacket for up to 12s voltage. Specs: RPM: 740Kv Shaft Size: 5mm Mounting Screws: m4 Motor Length: 85mm Motor Diameter: 46mm Motor Weight:650 grams(includes weight of jacket)Water Jacket Diameter: 56.4mm Mounting screw diameter required: M4 Mounting Holes 25mm apartBullet connector size: 8mmNote: To use 12s, check your ESC's voltage rating to ensure compatibility.
